larger than 2.10 tires and rims?
jd56
It's all about the tanklights
Mar 28, 2011
709
998
Norfolk Va
7   0   0
I need to know from the wheel/tire guys what is the clearance needed to fit larger than 26x2.10 tires on a bike?
The frame I'm working on is a Chinese built Murray. I dry fitted a set of 2.10 and there was plenty of clearance at the frame....but not knowing what wheelset I need to accommodate the larger 3" tire the owner wants, and if there is enough room to avoid rubbing the frame, I need some help. I'm thinking the frame wont have enough room for the larger fatter 3" tires, so how about 2.30 or anything larger than the 2.10" tires.
What size wheelset for the larger tires and what is the measurement that is needed between the forks? Is the question.
I have not measure the distance that is on the frame now....yet but, can.
Thanks
JD
Oh and the guys want blackwall tires with red flames....any ideas where to find such a pattern?
I assume those are $29 ea?
Still need to know what is the measurement on the fork gap for the these wider tires?
Also anyone seen red flame patterns on the sidewalls?
Thanks panelman
Sent from my DROID RAZR using Tapatalk 2
Thanks panelman
Re ; red flame pattern sidewall Duro makes them ,black tire,street tread 26x 2.125 with 3 red and yellow flames on each sidewall.
