The Renaissance Man
__CERTIFIED DIVER__ (Open Water & Open Dumpster)
Staff member
Moderator
Pro Member
I have read about the importance of using the manufacturers specific internal hub grease for the hub and plan to follow that advice. What I am wondering is how to clean it before I put it back together. I'm not going to take it completely apart, I've only removed the assembly from the hub. I would normally use a parts washer but I'm concerned that if I didn't get all of the cleaning fluid out that it might have some negative effect on the lube later on. Plus it might make it difficult to work the new grease through out all of the moving parts. Maybe it would be best to just wipe everything down with a clean shop rag and forgo the parts washer.
Any ideas?
Any ideas?
