- Joined
- Aug 27, 2022
- Messages
- 948
- Reaction score
- 1,946
So a bloke at work has seen the video's of my bikes n the trike,. And asked if I could build him a drift quad. Sure I said and set about some simple rules, I said I have one at home on the stand ready in wait, I'll modify it over a few weeks and at the end if you think its good enough it'll cost ya $1k......Showed him a pic of the mini quad and he said sweet!... looks sick as !
The motor and rear axle came out easy, theres no rust on this machine, the quad has a 100kg load rating, the guy buying it is about 5'11-90kg with a six pack... he's a huge bodybuilder dude! so I better not stuff this up LOL
theres gonna be some small support gussets here n there all over and under! im ordering a new 20mm / 610mm solid axle with mounts and sprocket n disc too, it also comes with hub's , wheels and sleeve's i'll rob the brake system off the hot wheels drifter and the 7hp motor as well will be robbed of it, no drama here,that motor is still new with about 90 minutes use! this is why I said i'll make this anyway and if ya dont really want it or ya pull out i'll just keep it or flog it off to someone else, in the end it will be worth every dollar in the $1k, the hot wheels drifter will be refitted with a 10hp and a new brake! no loss there only fun to be had!
If need be and the 7HP dosnt fit....Im gonna make it fit LOL ill chop the bottom section out and extend it a bit deeper to accomodate! in any case the fuel tank comes off the 7hp and i'll use the original/ maybe even buy a bigger one on top of the quad, the exhaust comes off and so does the air cleaner as these can be replaced with after market items that have the plumbing aleady done to move the exhaust and air filter for extra room! it may fit with these things taken off!
I was quite suprised at the motor, this quad cost $25, the motor had no air filter, there was dirt n grease and oil all over the motor and the fuel line had an inbuilt filter that I bet is chokers full! it wasnt running at all so it was bought with the intention of throwing this motor away and placing the honda clone 7HP in there!
ive not the knowledge to rebuild a small motor like this but im guessing the spark plug may be stuffed as it was the only rusty thing on this!
A look inside the exhaust port revealed a great looking piston with 2 good rings still intact, some good looking oil is present too! I say good looking coz its at least there and not dry as a bone.
and even the top of the piston had a familiar look, as in not too bad and been in use not too long ago!....maybe 1yr (just a guess)
But the biggest surprise was the carby, once pulled apart it was quite clean on the inside, you can see the used a red oil, the fuels evaporated away leaving the oil that was mixed with it! impressed as this tells me the motor had lubrication at its time of Death. maybe its just the ignition module or the spark plug...maybe both and the needle in the carby LOL.... in any case I have a senaky suspicion this motor may very well fire again one day, for now its shelved in bags etc!
so the first thing is to replace this spring, its flogged out this one and really is just a puppy spring, I have a few MTB springs with adjusters so one of those will replace this red spring!.
Note the flogged out bush's, looks like they continually rode in the same direction on an oval track maybe.. all leaning to one side! and heres one for ya... this machine was built and bought brand new by qualified people. Take a look at some of the welds on it! no better than some of my monster horror show welds! I feel great now LOL
And heres the removed axle and motor ready to be stored, im eyeing off that axle set up for a pedal trike later in the year, we'll see how I go!
Tomorrow im gonn remove the motor from hot wheels and maybe somehow stuff it in the quad! dosnt that motor look to be in a sad state!
