I have a Felt Cruiser that has 24X4 inch oversized wheels. It currently has a coaster rear brake setup with the offset rear sproket set to the outside so the chain clears the tire. The issue I am having is that even with everything aligned the rear sproket pops off the snap ring when under load, if I am pedalling hard. The sprocket is seated and I have replaced the snap ring a few times. I was just wondering is anyone has run into the same issue. Im thinking of just tacking the snap ring to the hub in a couple spots but wanted to use that as a last resort.
Thanks
Thanks
