Remove logos from tires
I've used Acetone to remove a logo from a vinyl seat before, but I'm not sure how it would work on rubber.
I just took a few of those stupid colored flames off of a Kenda with carb cleaner and 0000 steel wool. Had another set and the white was raised and it was actually a big chunk of white rubber made into the tire....Non removable. :cry: If you can't get it off some people have used black spray paint and just cover them up.
You might try Goo-Gone Extreme ($4.00 at Walmart). It is a little less harsh than acetone. I have also had them come off with Simple green and a scotchbrite pad. Just do a little test spot before going full bore.
