CRASH Pro Member Joined Jun 11, 2012 Messages 5,983 Reaction score 10,692 Location Visalia, CA Rating - 100% 63 0 0 Oct 10, 2013 #1 I have a Schwinn stick shifter that needs a cable. Is there anything special I need to get, or will any old cable from an LBS work?
CCR Mouth-Breather Joined Mar 9, 2007 Messages 8,106 Reaction score 298 Location Southern Illinois Rating - 100% 13 0 0 Oct 10, 2013 #2 Same cable end type you would use for the brake lever. Shifter cables nowadays usually have smaller barrel ends on them.
CRASH Pro Member Joined Jun 11, 2012 Messages 5,983 Reaction score 10,692 Location Visalia, CA Rating - 100% 63 0 0 Oct 10, 2013 #3 So I should be getting brake housing, not shifter housing then. Gotcha. Thanks
CCR Mouth-Breather Joined Mar 9, 2007 Messages 8,106 Reaction score 298 Location Southern Illinois Rating - 100% 13 0 0 Oct 14, 2013 #4 CRASH said: So I should be getting brake housing, not shifter housing then. Gotcha. Thanks Click to expand... sorry for the late reply Crash, the older bikes still used the same housing for brakes and shifters, the coiled inner cables with a standard brake kit will work fine.
CRASH Pro Member Joined Jun 11, 2012 Messages 5,983 Reaction score 10,692 Location Visalia, CA Rating - 100% 63 0 0 Oct 14, 2013 #5 Yup, got a brake cable from an LBS on Friday. Fits right in there.
