schwinn Suburban 5 speed Cassette
Aug 21, 2010
11
I rescued this bicycle form a grusome fate. It was a garden decoration. The bicycle cleaned up nicely and I have greased the front wheel, crank, and the rear wheel. The problem that I have it the cassette. How do you get it off? Or is there a way to lubricate it? This is all that is missing on this bike. I tired using WD-40 all over the sprokets to see if ti would seep in, but on the lower gears it worked fine, but the high gears are still turning kinda hard. Any help will be appricated.
saki :mrgreen: :mrgreen:
Should be equipped with a free-wheel cluster. There is a key that engages the center, usually you have to take off the outer nut and spacer to use it. A good bike should have one on hand and twist it off for you for a dollar or five. Cheap tool, but you'll probably have to order it if you want your own. Lubing the freewheel bearings would be done through the end, not between the gears.
