Shifter cable & brake cable ferrules questions
May 16, 2020
66
89
Gilman, IL
I am re-doing brake and shifter cables on my wife's 15 YO el-cheapo Pacific MTB. Not sure which is cheaper. me or the bike.
Do I really need ferrules for them? Are metal shifter ferrules worth the cost, compared to the plastic ones? I have metal brake ferrules. I bought new stainless brake and shifter inner cables, and mid range Jagwire housings. I would like the new stuff to operate as best as possible without spending too much. BTW, the derailleur is an inexpensive Shimano Tourney RD-TY300 and new Shimano trigger shifters.
Never have done this before, so I don't know what is important. Any advice would be appreciated. Thanks, guys.
Most important thing is running them so the curves are smooth and making sure the cut ends are straight and clean. The trick is walking the line between not being too tight, but not so loose that they flap around while riding I like to form them something close to the curve they'll take when installed and cut them like that. With shift cable, if you just get your measurement and cut the housing when it's straight, when you curve it for installation, the metal wires inside the housing will take on an unwanted angle at the end with the inside of the curve sticking out farther than the outside because the arcs they scribe will be different lengths. If that's not an easy thing with the tools available, you can cut the housing when it's straight then form it into the curve you want and grind the end so that it's at 90 degrees with a bench grinder, belt sander, etc. Brake cable is less fussy—just make sure the metal coils within the housing don't drag on the brake cable and that the inner plastic jacket is fully opened (I cut my housing with an angle grinder, so it melts the inner liner at the area of the cut, but an awl or round jeweler's file fixes that easily).
I've not really had an issue with plastic ferrules, but they can bend at the cable stops if they're at the end of a section of housing that moves a lot. I've only really had this happen at the rear derailleur, but it didn't seem to cause a problem. I would use some kind of ferrule, though, as shifter housing is made up of parallel cables running the length of the jacket, so at the ends, they're liable to float around if they don't have something stopping them. In theory, the cable stops can accomplish this, but they're usually designed to be used with ferrules, so they'll allow way too much play and opportunity for the wires to move around inside the jacket and possibly cause it to split.
Another thing I do if the cable stops are located in a way that allows it, is cross the shifter housing past the head tube instead of using the cable stops on the same side as their shifter. It will mean that the cables will cross over each other under the down tube in an X pattern to reach the proper channels in the cable guide under the bottom bracket, but the drag from that is slim to none. The benefit is that the housings take a cleaner sweep into their cable stops both looking better and reducing friction while also flopping less when riding.
Index shifters need modern linier core housing, brakes and old friction shifters usually work fine with the common cheap spiral core. I tend to clip them with heavy duty wire dykes and open the holes with an ice pick, but an angle grinder definitely works better. As for housing ferrules, definitely use them except on some examples where the stop or component has a tight entry that serves that purpose. The little doo-dads that squeeze on the end of the cable itself so they don't unravel are also a **** good idea.
Thanks guys for the detailed info. Really appreciate it.
This is a great forum, lucky I stumbled across it. Thanks again.
Bill
Great advice above, especially about which housing! Grease cables! Pull it through a little grease in your fingers. They will last nearly forever!
Also because it was "mentioned," I want to reinforce it, "use housing ends!!!
Good luck.
It may be sloppy, but I have run a lot of cables without ends and have not (yet) run into any problem. Some applications need ends to run smoothly, depending on how the cable fits into the brake, brake lever, shifter, or derailleur. But others, where the cable fits neatly, seem to operate fine without ends. For lubrication, I squirt a little silicone spray through the housing before running the cable.
