tikiharl said:
Hey Cman,I think you are on to something about the chain tension. It would be quite the coincidence for both hubs to be faulty.This would explain how it seemed to fix itself a few months back on a ride and how it is riding fine now after this last episode.I belive that there is a sweet spot where the chain needs to be as far as tension. If it does it again the first thing I will do is adjust accordingly. Thx guys :wink:
if it's that finicky on chain tension then they are still both faulty hubs. the worst you should have to worry about would be the chain bouncing off (too loose) or the hub being noisy- popping, knocking sounds from binding (too tight). a long shot, but perhaps it's a problem with the chainring rotating on the crankset, is the little 'nub' on the crankarms contacting the chainring solidly (if it's a one piece).......?
