BO15 Splinter (or how I learned to love a LOT of sanding)
Aug 23, 2012
611
872
Kansas City
2   0   0
I'm finally going to build a bike I've always wanted to make. Been throwing around ideas for years and started collecting parts and materials since the end of last year.
The plan, pretty close to this design:
The material:
I've done some woodworking before, nothing on this scale, and 4 months is going to be a tight time-line.
Captain Awesome
👑 Lord of Irrelevance
Staff member
Admin
Moderator
Pro Member
Aug 9, 2012
6,132
11,149
Da beach
3   0   0
Laminate monocoque frame or layered and "assembled'? Wood wheels too? :grin:
Aug 23, 2012
611
872
Kansas City
2   0   0
Layered and "assembled"! Yes, wooden spokes at least.
Here's the parts I have so far
Generator from hub for lights, roller brakes for stopping and a 7speed internal rear hub
Captain Awesome
Staff member
Admin
Moderator
Pro Member
Aug 9, 2012
6,132
11,149
Da beach
3   0   0
Pro Member
Aug 31, 2009
31,852
39,585
Historic Savannah
130   0   0
That design has the vibe of an animal skeleton and rib cage. This is gonna be fun to watch.
SkyknightJohn
RRB Supporter
Pro Member
May 21, 2015
639
2,206
Charlotte NC
2   0   0
Yeah, figured that would be the easiest way to get a solid hold for the bottom bracket.
I need to find a donor "pipe" for the head tube that would fit a 1 1/8 steerer.
FWIW- a 1.5” x 0.083” gives an i.d of 33.88mm - perfect for an EC34 headset, after a bit of reaming. I’ve used them before. Aircraft spruce will cut and ship even small lengths of 4130. Only $6.60/ft + shipping.
Or, of course, cut & grind a cheap steel frame (c-list/ dumpster/ roadside). But $$ vs. time and effort is each person’s decision.
Aug 23, 2012
611
872
Kansas City
2   0   0
Any reason why this, in a 34mm ID wouldn't work?
SkyknightJohn
RRB Supporter
Pro Member
May 21, 2015
639
2,206
Charlotte NC
2   0   0
I imagine that would work just fine. I can only weld steel, so I've only ever looked at steel. You may want to put a caliper on the headset bearing cup, where it inserts into the head tube, just to be sure it'll be a tight press-fit. I don't have any here that are not installed to check.
On the steel at 33.88mm, I do run a headset reamer to get the "proper" slope and exacting dimensions, but not much material has to be removed. (an expensive tool, but I was trying to build a lot more frames, once upon a time.) I suppose if the press fit is not tight, adhesive would work, but just make the headset cup a more permanent fixture than standard. Not the end of the world.
Jan 31, 2011
632
1,398
2   0   0
Extremely ambitious. Hopefully once finished it doesn’t lumber down the road.
furyus
