steering bearing race help
Dec 28, 2009
52
2
I have a 24" Schwinn frame and a Hawthorne fork. The lower Schwinn bearing race that is pressed on to the fork stem is about. 010 to large on the ID. Is there another race I can use or do I machine a spacer? The Hawthorne race does not contact the bearing enough to make me feel comfortable.
i have encountered that problem before...
i would use the schwinn race and make a brass bushing...
i cut a thin strip the width of the race...
then wrap it around the fork tube... mark the over lap...
then cut it a little short...
make two or three as needed...
use a flat blade screwdriver to push your spacers in place...
just make sure the race is tight... like it had been pressed in place...
some hardware stores carry hobby metal...
thin sheets of brass, copper, and aluminum...
i have used 5/8in soft copper tubing as shims for handle bars that slip...
works great... the copper being soft will crush a little...
putting a tight grip on the handle bars...
oh...
almost forgot...
sometimes you can wrap a shim made from a pop can around a loose handlebar stem to tighten it up in the fork...
some bicycle parts just will not work together...
but that does not stop me from trying...
ponytailmike
mike
