stuck seat post
Dec 11, 2011
931
16
Pittsburgh,Pa
6   0   0
On my Monark Silver King, the seat stem is sorta like a quill steering stem,and the bolt was missing when I got this bike. And the stem was tight. I tool a long phillips screw driver and pounded the wedge down, and the stem now rotates, AND I got it to raise 3/8 of an inch. And it is tight, and not coming up anymore. I had a pipe wrench on it, and beat it up to where it is now, but the stem is mutilated. If and when I get it out, I will put in an altered steer stem. The big problem is I dont have a big bench and vise to hold the stem while I twist and pull on the frame, and cant find my 5 pound slide hammer I once had. Anyone got any ideas? Besides taking it to a machine shop? I cant take stuff in and out at my work, where we DO have the equipment to do it.Its worse than airport security. Its a NO METAL inspection, as we do precious metals. Anyone around me with a heavy vise/table combo? DogDart? HELP!!!
its stripped, and I have a 1/4" hole in the post that I put a hardened rod thru to pull and twist. No good. PB Blaster has been sprayed in it for a week...
I had a wedge nut stuck in a steer tube that no amount of beating could remove , I ended up fashioning a spacer big washer combo and used a bolt to draw it up , similar to using a steering wheel/ harmonic balancer tool .
aluminum frame, so oxalic acid is a no-no.
Im really hesitant in using a puller that bottoms out on the 80 year old aluminum.Im hoping to either use a large dent-puller slide hammer, or mount the stem in a vise and twist and pull on the frame. The stem is LOOSE totwist.
Oh alloy frame, Errrr. I guess just keep oil soaking and pray, curse, beat on it, twist it, and oil it some more.
Got permission from the security officer to bring the bike in the shop. We cut the stem flush with the frame,then used a scroll blade in a saw-zall, and split the stem,twice. Pushed it down in the tube, pulled out the outer sleeve, turned the bike over and the stem fell out. 1/2 hour,tops. My boss is a git'er done kinda guy. Security x-rayed the frame on the way out,to make sure I wasnt smuggling out the good stuff..... Now I gotta alter a steer stem to work as a seat stem.....
