Looking forward to a cool and wacky build as always. Your ideas and execution are always great to follow.
How's about a tabletop created to look like a rear fin that hinges on a rear book rack.Pretty sweet idea for a bike build! Looking forward to seeing it all come together!
Sounds like a cool idea to me! Not quite sure how it'd work, but I can kind of picture it.How's about a tabletop created to look like a rear fin that hinges on a rear book rack.
Vertical fin (maybe even a backrest...), folds down flat for a work surface.
I like 'Taco Taxi', and for the table you could do a drop-leaf instead. That way, when both leaves are down it frames out the back like pannier bags, and you can still use it as a rack. You could even mount a condiment rack in the center, and then each leaf can be folded up for dining on both sides. Just a thought.I'd love to have one of those. But no, small quick picnic n' split. CanAm style...
As far as the tabletop fin, picture this, maybe a 30" tall fin like the tailfin on an aeroplane, just the vertical part. Now about a 3rd of the way up a hinge connecting it to a book rack. So that when it folds over, it lies across the book rack (probably need a swing down leg to rest on too)
Just a couple thoughts on this drawing...front of the frame needs to come up a bit more to get the center bar level AND the bottom of the fin lines up with or is at least parallel to the center bar. I've got a repo chrome 9 hole Schwinn style book rack perfect for this. Next Sunday (the 28th) is the Chicago Taildraggers Tamale Ride. I wonder if I can have a roller by then?
Mike Brittan built a fun front trike using one of those metal cage plastic totes for the front box a few years back.
I lose my stuff all the time. Seems to vanish sometimes. I've got three plumb bobs that I haven't seen for years. Last time I needed one it was a string and a 1/2 inch threaded square nut.And I'm out of wire. Ha it's like hot glue for steel with the little wire feeder from Harbor Freight but you gotta let it burn in cuz it won't do anything thicker than bike tubing. Even so I've got sleeves inside and out on these joints. So with my primitive plumb bob and my cardboard square it'll be fine... Really it will ...
Register today and take advantage of membership benefits.
