Tap Frame for Klunker Derailleur Hanger
Feb 13, 2009
1,421
2,104
21   0   0
Just picked up a Monark frame with rear dropouts where I could use Sandmangts's idea on tapping the right rear dropout for a derailleur hanger. Does anyone know what size tap should I use?
Thanks in advance for your help!
Tap to whatever size bolt you've got to mount the derailleur. It won't be very big; maybe 3/16 24 or something. That is if you're mounting it the same way I think you're talking about.
Here's a shot that's hopefully close enough to tell of one I did. It was just a little centering bolt with an axle mounted derailleur which is probably the easiest way to go and the least modification required.
Are you meaning, to have a hole below the rear wheel axle, that the rear mech screws into. Like a lot of bikes have.
If so, its an 10mm x 1.0mm tap.
heres a link I found to them.
http://www.drillspot.com/products/51188 ... r_hand_tap
I seen that small japanese motor bikes have 10mm sparkplug threads. And I think they also use that thread in brake parts too.
So a motorbike shop might have the tap.
