WBO 2018 RULES - READ FIRST!!!
Status
Not open for further replies.
Owner & Founder
Dec 31, 1969
18,502
7,504
Texas
Time frame: January 1st 2018 to April 1st 2018.
Builders will have 2 options, Modified or Scratch-Built. This is to reflect the two styles of builds that RatRodBikes is famous for and we would like to see more of! Both groups will be voted on together as one.
Modified: Build a cool bike using a factory frame. Frame modifications are allowed.
Scratch-Built: Let's use the Uncle Stretch definition of Scratch-Built: "In order to qualify for a scratch built bike, you have to build it complete. If you use the head tube and bottom bracket from a built bike, that is acceptable, but you have to build the frame. That includes the back triangle." You can use tubing from bike frames, but not previously welded together sections. You can use factory produced forks though! We are seeing a lot of builders stepping into the scratch-built area and want to give them somewhere to play!
Please don't skip doing the big build-off just to do these, the big build-off should remain the big event it has always been!
Status
