The front end looks great as is in my opinion! Love the Pup!
O.K. I am done with the chain guard. After painting, sanding to give the worn effect, then using the torch smoke to add some aging, I cleared it over with satin to keep the finish dull. I am not totally happy with it, but it'll work I guess.
So just dampen the metal and the moisture keeps the stencil/mask (standard copy machine paper) in place why you spray. Thanks have to try it.Thanks horsefarmer, in my best caveman technique.........I first found the graphics that I wanted and printed them from the pictures. Then I took them to the copier to enlarge or shrink them so they would best fit the area that I was working on. When I was satisfied with the size (make multiple copies!) I then sat down with an exacto knife at the table with some sheets of construction paper under my work to protect the table and proceeded to cut out the areas that I wanted to paint through. According to the graphic, this will be a long tedious job, and you will have to be very careful in thin areas. I intentionally left some areas thicker to keep from tearing through between open areas. Finally, I used a damp cloth to moisten the area that I wanted the stencil on, then when I had the stencil positioned I gently tapped the area with a dry cloth. Paint fairly quickly because the stencil will not stay adhered to the metal as it dries. I imagine that someone on here has figured out a better way to do this than I have.
a light tacky stencil spray would work, it wil not be permanent
try the sticker paper for printer as it not prmanent
I like the tank , I didn't catch that we are using the same one for our builds
