Ok seems several people are curious about what welder to buy and build a frame with. The one I chose 25 or so years ago is called a Miller Cricket. They had just come out with these 110 volt welders. They are supposedly good to weld up to 1/4 mild steel. I have used mine for everything. I built several Street Rods, welding everything on them ...Front nova clips ...rear 4 bars and everything in between. Mine will use argon gas ,but I always use flux core wire. The difference is they put the flux to weld inside that small wire ,and with the gas bottle it comes out over what your welding and dosent need flux. The gas is cleaner on your weld ,but I never run out and have to have the bottle filled. :wink: They make alot of 110 volt welders that you can buy. They are my choice ,because they are smaller and you plug them into a regular plug in your garage. Most have 2 knobs ...One will be for the heat setting...usually 4 different ranges....the other will be a knob for the wire speed...that is how fast the wire comes out.
The cheap ones are made in china. An old welder friend told me the way to judge a welder is by weight. Pick it up and it should be in the 40 to 50 lbs range. I love quality...miller has made these forever. They will cost in the $575 to $650 range for one. Mine has lasted for 25 years so far no problems. if your serious about welding buy quality. If you think you may or may not get into it buy the cheapest one you can find ,because you probably wont use it anyway. I wouldn't have a problem buying one off of C/L. Let the other guy pay retail and then decide he wont use it. Maybe he needs money or getting a divorce....look for the deal. 8)
