What Engine kit to buy???
May 27, 2010
54
8
Hello All,
I'm looking to buy an engine kit for this bike
I'm pretty sure i want to install a 66cc 2 cycle engine. However, I want something that will actually run and last a while once i install it; I am willing to pay a little bit more for an engine kit if there is one out there worth buying.
Any help is appreciated!
WillyB.
Well you can get the same kit for 50 bucks less on several webstores and no matter what the sellers say they are pretty much the same..
There's a lot of good info about these engine kits on this site.. :D
http://motorbicycling.com/
Thats a really nice bike btw.. :D
Thanks for the help and the compliments! I do want a center mount engine; I just like the looks of the early motorcycles. Was hopeing there was something other than one of these chinese motors to mount up, but it looks like that Phantom with the HD hub may be the route I run. If that hub is worth the extra $$ i'll just cross my fingers and hope for a good motor :oops:
Thanks again,
WillyB
Just remember 3 things with the Chinese engines. Check the head torque daily. 120 inch lbs, , not foot lbs. The more you do it the less it will require tightening. If your head loosens you will blow head gaskets often. Don't run it at full speed all the time. Cruise at 3/4 throttle, and use full power for short bursts and hills. These little things die if you wring them out 100% all the time. Mix you oil on the high side of factory specs. If you can mix between 4 oz and 5 oz per tank, run it at 5. Keep it lubricated well. I use redline synthetic racing two stroke oil myself. They say synthetic doesn't build up as much carbon in the muffler.
