- Joined
- Apr 26, 2020
- Messages
- 1,594
- Reaction score
- 5,081
Thanks Doc. I was lucky to get at least the frame and fork done yesterday as it will be raining here for the next 6 days.That blue paint is everything, love it!
Thanks for the advice Doc. I think I’ll also do a test run using the same paints on a different chainguard.I like the Electra rims better than the gold for two reasons. One, the color, that white would look, as you said, more old school. I agree, there’s something about the look of old bikes with painted white rims. They even make whitewalls look ‘fatter’. Two, the profile on those old Electra rims is ‘classic’ looking, like a ‘smooth’ dropcenter look.
As far as masking off raised areas, my only advice is patience. Of the ends are ‘blunt’ ,as in have a rounded end, you can sometimes find round decals, like yard sale ‘for sale’ dots, that don’t have a lot of adhesive on them. Put the dot on the end and run tape over the bulge, trimming carefully with an Xacto knife. Since the chainguard is flat, you can lay a metal ruler down to run the knife against for a nice straight line.
Lol I prefer most bikes with black walls. I've almost learned to accept tan.Matti preferred this bike with black walls.
Thanks. It rides great that I’m afraid adding 12lbs or so in fenders, the chain guard, skirt guard and truss rods will slow it down. Guess I may have to lose the same in body weight to make up for it.Very sharp ride. Great flow.
Cyclists be like:Don't lose the weight. Just increase your squat reps!
Any tips on the best method to mask over the raised white sections would be highly appreciated.
Nice work on those chainguards KF. Thanks for the advice. I did the same thing as you. I spoke with the painter last week who did my Mustang and he recommended the 3m tape so I ordered a roll of the 1/4”.
I also remembered I had an unused stencil kit for a prewar Roadmaster made from the same tape and will use some of it to paint the ends of the fenders. I am going to do a test run on a part using the blue paint to determine how long I need to leave it before removing the tape. I believe the tape needs to be removed while the paint is still tacky and that you pull it back on iteself. I’m using high heat engine paint which dries quickly. my guess it is 10 to 15 mins at most, then begin to remove the tape.
Its the good stuff made from vinyl. Thanks for checking.If the 3M tape you ordered is vinyl stripers tape then that is good. If it is just thinner 3M masking tape, then it doesnt hold the edges as well and doesn't handle curves as well.
That's bleepin' radddd!!The Powerblocks are incredibly sticky and fast. Yesterday when I had the bike wound up on the test ride, the front tire was kicking up a heap of tiny stones at me. I’ve never experienced that before.
