- Joined
- May 29, 2020
- Messages
- 9
- Reaction score
- 13
I am gonna start my first from scratch motor bike build. Pretty much gonna build a totally custom bike. Its gonna be a big project so ill slowly be adding when I can. I'm unsure of many details at the moment. Most of the parts like wheels and hubs will be off mopeds. I'll be starting at the motor and build the frame around it.
Motor. Is an e50 Austrian twostoke moped engine with 50cc displacement and a 12mm carburetor. Im going to put a much larger cylinder and piston on it at 74cc. It has many extra bost ports and a large reed block as opposed to the stock pistons port intake. It will also get a much bigger carburetor at 24mm. Twice the size as stock. Ill be making a custom intake for as well. The stock crank has a bronze bushing in at the wrist pin. I'll be putting in a much better crank with needle bearing on the little end to handle the extra power. The centrifugal clutch will also be upgraded with extra beefy springs so it engages when the motor is in a higher rpm. There will be an extra brace across the clutch post to help keep everything lined up and ridged.
Also will be putting on an expansion chamber to create a huge boost in performance.
Someone messed up the studs on the crankcase pretty badly. Looks like they tried to use epoxy without mixing it together first. The helicoil threadrepair isnt even flush. Dont even know what was going on here. I cut out big chunks of aluminum with cutoff wheel down past the epoxy and filled it all back in with new aluminum. I'm gonna have to add more metal and sand it all flat and true / perpendicular to the piston. this is how it sits now.
