26” “Stranger Things” Mike’s bike build
My son likes the old Huffy frame better, so I think I’ll just save the black frame for another project.
On the source bike - the more I look at that bike I think it is like either a 24” or 26” length frame with 20” wheels. I have a 20” Schwinn frame and 70’s Murray cantilever frame, and neither are nearly that long.
Look at the distance between the seat tube and rear wheel compared to the normal 20” cantilevers.
The head tube is just so short on this bike that it is going to take some mods to ever use this springer.
They make those steerer tubes for the springers in different lengths and are on eBay
5.5"
7.5"
8.5"
9.5"
Somebody on here might even have one you could swap. I'd assume that head tube is more on the 5-6" side?
The actual bike in the show looks more like a normal 20” frame, but I wish I could find a better side shot.
Yeah, I bought a springer fork years ago and finally found a frame it fits right when I tried it on the frame I'm using in the build-off this year.
Sent from my SM-G986U using Tapatalk
5.5"
7.5"
8.5"
9.5"
Thanks! That’s good to know!
I can clean up the forks and truss rods on this springer, but the spring and yoke are going to need to be replaced. I knew they were readily available, but I didn’t know the different steerer tubes were out there.
5.5"
7.5"
8.5"
9.5"
I wish there was one long enough to fit my Electra Townie! LOL
You should make a "Starnger Things" bike!
Sorry @Rat Pilot I'm ruining your thread. I'll keep quiet for a while now. Promise
No way, man! I love activity and goofing around. That’s what makes it fun. I appreciate the input.
This chain ring looks pretty close to the Schwinn one and cleaned up nice, so I’ll use it.
So I hoped to have it largely together this weekend, and I achieved my goal. Turns out it was a little harder to actually hit the proportions of the Schwinn repop, but I think it captures the look of the original one in the show, just supersized. My son is totally pleased with it, and that’s good enough for me
That said, it’s a cool looking bike, even if I had never seen the one on TV. Only difference I would do if I were building it for myself is I’d use a narrower 26 x 1.75 on front.
I’m waiting on the chain guard, and a new springer yoke assembly with the angled head tube bracket.
I guess I’ll finally get my Huffy Dragster XL back! :)
Now, I have to start on a purple one for my daughter!
P.S. - My son also said he was OK with it not having the mid-rise sissy bar on it. He said “That’s cool - that just means “Eleven” will have to hold on to me tighter when she rides with me!”
(You’d have to have seen the show to get that!)
I think the springer sits this way because of the legs length too, and just changing the yoke assembly won't do it. You'd either have to use longer steerer tube and put the bracket higher with the spacer, either use shorter legs, or do some custom adapter.
It doesn’t sit that bad on this frame. It only did that on the 90’s Huffy frame, but I did play with it and it seems like angling the yoke does rake it out more.
There’s a huge difference of how it sits between the two frames.
I actually played around with the springer this evening and ended up cutting a little off the springer and shortening the bolt and it looks pretty nice now.
Before:
After:
The chainguard came in. It is going to require a little modification, but I think I can make it work.
