Don't want the same air cooled whizzer knockoff everybody else has.
Guy I work with had it in the rafters of his garage. Twin Cyl. 1938 4.2 hp Johnson Outboard.
Should I run the engine inline with the frame or Across the frame.
Need to figure out water pump and radiator also.
Might be able to shorten up original bottom end and use the water pump and 90 degree drive.
![](https://proxy.imagearchive.com/8ec/8ec3912b98822714cb87a286ae432a6f.jpg)
![](https://proxy.imagearchive.com/a71/a7196adf735c7b9058bc913850249833.jpg)
![](https://proxy.imagearchive.com/d3a/d3a931b6d1acebb60203613802790dd6.jpg)
