Converting caliper brake bike to v-brake bike
man i need one of those, do they make em in the states?
Outlaw :mrgreen:
wonder if that v-brake addapter for the front would work on the back. i didn't see one for the back.
Outlaw :mrgreen:
I got mine fitted, it seems to work fine :)
The top-centre bolt was only threaded on part of the length but I added a large spacer from an old hub axle and four washers and that fixed it. The hose clips were a bit awkward.
now for the big question...
do they give you enough reach to run a 24" rim in a 26" frame?
and another big one...
will huge fat 3" wide tires fit in there?
thanks for any info...
--rick
Rick,
Remember the adapter only re-creates a regular v-brake set up.
What you could try for 24in wheel in a 26in frame is adding a piece of metal, drilled at each end to the top of the adapter to lower it's reach from it's fixing point above the bike's fork-arch.
