Need help installing 3spd hub
Nov 28, 2010
124
Virginia Beach, VA
I have a Sears 3 speed hub I'm planning to use on my next build, but I'm not sure how to set up the cable and linkage to the hub itself. Anyone have pics of this? There is a cable pulley and I'm not sure where it goes?
for future reference "shimano 3 speed internal"
the other clamp holds the cable tight.
usefull info, most of the suntour stickshift's work with the shimano.
if you look hard enough, you can still purchase n.o.s. suntour stickshifts.
btw you don't need to install that puley. just use a standard shifter cable anddo away with the clamps. i usually run mine inside the frame, so i always opt for the standard cable.
