Rapid Transit System / (was) Fast Bracket - Class 2
Jun 5, 2012
558
1,752
I want to make a nice rider that is customized but not so overly done
So I am starting with this aluminum Magna oasis frame
Dirt cheep and looks like a schwinn fast back
5bbe9e44-e921-4220-84a4-5c1e657a2cca
Pulled off some parts from previous builds
Fork is aluminum
Rear tire is 700 deep v with a 700 x 1.35 slick tire
and a modern 2 speed kickback
The lettering was made using reflective tape but I will be redoing it in white reflective tape
and a different goodyear letter template
Not much to report
spent most of the time trying to determine if I want ape hangers with a small seat
or straight mtn bike bars (drag bar look) with a banana seat
I did however remove the old rubber paint and yellow reflective stickers
and sprayed on a new coat of rubber paint
When I last did this I had cut out the reflective stickers first
then sprayed the rubber paint around them
but the paint bleed a little into the reflective part
So this time rubber paint first
THEN apply the white reflective stickers
Now should I stick with the goodyear eagle script maybe do Hoosier
or another script for the drag tire look
new-pair-goodyear-eagle-drag-racing-slicks-33-18-15-sfi-rims-wheels-americanlisted_30999215.jpg
f2352e04-ad8a-49af-bc61-d67406935b35
I had not done much to "fast bracket" knowing in mid November I will have a week off in which to work on the bike
So until then I was looking up postings on offerup
apparently it is the new place to find deals rather than craigslist
When I stumbled upon this add
It was cheep so I bought it and brought it home to find out more
Turns out the frame is a GT Rapid transit
but all the good parts (7 speed internal hub with roller brakes) where long gone
Other than a neat looking frame and a springer fork
The rest of the bike was a real Frankenstein's Monster
Finally have a week where i can do some fabricating and mock ups for RTS (rapid transit system)
First I was able to find a suspension fort that fit (just barely)
now I can go for more of a cafe racer look which I feel more suits the frame more than a traditional muscle bike look
Dug this gt spider out of storage along with a chainring that works with the lines (For the most part)
But since this requires an american bottom bracket crank or a bmx three piece crank
I had to go on offerup and score some cheap bmx euro bottom end bearings
most are 19mm and one is a 22mm
still need the actual cranks and shaft
but hey its a start
I wanted to use the banana seat without the typical straight sissy bar
since the frame has so many nice curves
What I ended coming up with was modifying a 20" springer to make a somewhat floating seat
Close Up
I drilled a hole all the way through
where the 2 top rear bars are connected by a horizontal tube
to attach the base of the seat support
the middle hole i use to attach the brace bars
the part that attaches to the seat i drilled a hole at the pinch point
all the parts that i modified
It seems to support the weight well enough
but I have a contingency plan using a 26" springer if this fails
Finally (after almost 2 weeks) I was able to get the bmx euro adapters plus the 19mm spindle and cranks installed on Rapid Transit System
Turns out whoever frankenstined this bike the first time managed to do a number on the bb
I was starting to be afraid that I wouldn't be able to install any type of cranks on this
and end just up with an adult strider
Now that the holiday was over it is time to paint the frame
I think I will just go with the self etching primer spray can gray
Now that I plan to sell Rapid Transit System (let the new buyer pick his own color)
Photo before I disassemble to paint the frame
there are no hbars on it yet
I realized over the weekend that a set of clubman style bars would fit the overall look of the bike
Now I need to see if i can pick up a cheep set before the end of this buildoff
BTW If anyone is curious why I am selling
it is mainly due to recently acquiring a new long term project
http://www.ratrodbikes.com/forum/index.php?threads/hang-on.105211/
So I would like the extra space and money
plus I found I do not actually like 2 speed kickback hubs
I seem to prefer the 2 speeds that are shift actuated
I got lucky and found some 1" clubman bars that where cheap and fairly close to my location
Unfortunately after trying them in both orientations on the bike
I decided that I need to find other bars
Looks like they will be used on another build
just
Doesn't
Look
Right
I see what you're saying. Those bars have the sharp angle, where they frame has more of a smooth flow to it.
I'm just tossing an idea out last second, but maybe a low-rise ape hanger in black?
CRASH
The straight ends of the bars (against the frames curves) are actually what is bugging me most
I am going to stop at the local co-op and see what they have available
as for low rise ape bars I can try the chrome ones I have (do not have any in black) after I reassemble the bike
There is a possible backup set I also what to try
The problem with this bike is that the frame is so unusual that I think it needs unusual looking bars to go with it
I wish I had time currently to hunt down cheap
GT pretzel bars
or time to order and have shiped
Ruff bent ape hangers
and try either of them on the bike
