So I am definitely a noob when it comes to skiptooth sprockets and chains.. I know very little about either. But the board tracker that I am replicating used a skiptooth setup on the pedal side, so I need to put something similar together. I've already purchased a skiptooth crankset from a fellow board member, which I may need to modify a little bit to get the look that I want. I will also be picking up a 22T rear freewheel which will have every other tooth removed to turn it into a skiptooth. The hard part is the chain though.. The chances of finding the exact chain that I need are pretty slim, and I don't like piecing something like that together. Is there anything else I can do? Obviously I cannot just use regular bike chain, since the real skiptooth crank sprocket is much too thick for that. How about motorcycle chain then? The bike that I am replicating seems to have very thick chain which was also nickel plated. Would I be able to use that with my narrow (1/8") converted skiptooth rear sprocket? Or would there be issues? Just trying to get this straight in my head so I can put a plan together. TIA
