threadless forks
You would need a threadless neck
like i have on my american flyer
Or like this
actually you dont need a threadless stem(hooch did rosemary with a standard neck) you will need to find out if the frame has a 1" or 1&1/8" headtube other than that........just a headset(if you decide to go with a threadless stem)
make sure when you get a headset that the cups fit. like if it is 1 inch there are two sizes you will most likely need the BMX size. oh yea and the steer on the fork comes long. make sure you mock it all up mark THEN cut the steer
