TOOLS FOR BIKE BUILDERS
hello guys
I promised more pictures with my roll tube bender
here I have a new cutter with fast holder
in the next days I will post some pictures with bend pipes and some pipes cut with my notcher and I will show my jig.
hello Designit then all materials I buy from a scrap yard in my town nörrkoping sweden .
it was an industrial machine.and I took some parts that I need to build my tools.
but you can find them on internet in your country or you can go to companies who build aluminum doors, windows, frames and industrial machines.
or like my go to scrap yard :D you will find there every thing that you need to build your tools very very cheap :D
you only need little imagination on the place, to see what you need for your needs :arrow:
kindly Valy
amazing ingenuity, vision, and execution of ideas and designs. cant wait to see more from your shop.
thank you sensor for your toughts but my bikes I build them before I had this tools .
I build them in my apartment with a grender a drill and a welder.
my bikes are made last winter .
and the tools what I show you now I build them in the last 2,3 weeks .
soon I will put pictures with my new projects using my new tools, and show you how they work.
kindly Valy
hello X-RAY and thank you for your nice words.
I will try to show you guys all my tools and to put pictures to give ideeas for beginners to build own tools cheap and easy
hello guys I will show you my first pipes bend with my roll bender
here you can see my tool room dont give me space to bend enaugh
here when you bend a pipe you must to take in consideration minimum 300 mm lose pipe on the each side the distance of the midle roll and the side one
here is the first check on the jig
here you can see the part what I need to cut and haw luck the pipe inside the circle .the pipe is 53 mm x1,5mm very strong pipe stinless still. I work 130 minutes to bend this pipe :oops:
Last night I dont sleep good. and today I bought a drilling and milling machine :D now I can build some parts more easy,
like TORK ARMS FOR ELECTRIC HUB MOTORS,DROPS OFF etc.
come more tools naw i have posibility to buildem more fast :D
hello guys it is time to put my tools to work. I will show you haw I build my first tork arm for my bike.
I start with a peice of aluminium
it is so easy to do it when you have proper tools :D
tools make the jobb to be easy and fun to see what you can build with them :D
here it is the first check on the bike
second check on the bike
here Isandet and polish the chanel
here I have my new tools to sand and polish my building parts :D
hire I must to build some parts to fit my new sand paper brush and the polish roll.
