- Joined
- Sep 17, 2013
- Messages
- 4,213
- Reaction score
- 9,109
Yellow.Bendix YB rebuild for the DX , geez these thing are like artwork !
Ive stripped all the flaking yellow paint.....what color to repaint with ???????
Yellow.
Good choices, you won't be let down. Not going to comment on sticker removal...Gathering parts... a Tange headset and SE forks
The string method is ok, but I find it difficult to accurately measure both sides and never seem to get the same measurement. I always wonder if the frame is ok. I would recommed making one from old or used straight wood. You could use vice grips to hold the two pieces of wood together and another vice grip to hold an old hack saw blade indicator in place. It won’t take much longer to make. If you don’t have wood then string. It has to be pretty far off for string to work. Most people just spread the drops without aligning the drops or even doing a string test. But, when you finish and ride, if the bike doesn’t track then you won’t know if it’s an off center wheel, frame, drops or fork problem.Great pics US56..., thanks,
I'm assuming I can use the "string method" as described in the Sheldon Brown link above in place of your frame alignment tool. Great idea for the axle truing too !
Thanks !
