I have one of the older 26 white wall slick jerald sold and it won't seat on the rim right anyone else have this problem?
its on a 140 spoke 26 in rim 1.75 wd if that helpsPlease don't be offended, but I must confirm that you are indeed attempting to mount it on an ISO-559 rim, correct?
Yup...it should fit on a 26x1.75 rim. Is it too tight? Too loose? There are several diameters of 26" rim, so that is why I asked.
It's understood...but it doesn't make sense. The Jerald ought to fit correctly on the "smallest" of the 26" family of hoops. The fact that it's loose makes me think that your rim is somehow undersized. Are you quite certain it isn't 24"?
i'll try moving the tire on the rim and lube the bead and see if that helps. I also noticed the side walls are really thin. maybe that has something to do with it.i took 26 tires off. i'll snap a pic of it. in some spots the bead wont seat
i will it's just strange for it to do it now I've had the tire on a rim since 2012. all i did was air it up for the summer.Ahh, yes. A little soapy water on the bead may help get it slip on more easily. If you find a spot where the tire is "dismounting," check the area 180 degrees opposite. I'm betting you'll discover the bead is pulled inward there, causing the original spot to appear loose--it isn't. Just be persistent and the tire should mount squarely and properly along the entire bead seat...eventually.
