The toughest challenge of this was getting enough axle length. I used the longest Sturmey-Archer axle avaialable, but even that was far too short for a normal installation on the right side. I used a conical countersink drill bit to countersink a hole into the adaptor claw, then I bevelled the edges of the special axle nut so that they would fit into the countersink. This only gives 5 or 6 threads of engagement, but since the countersinking prevents the axle from being able to slide forward, that is enough. Axles on internal-gear hubs have a tendency to rotate if not secured solidly, so I took extra pains on the left side to use the appropriate anti-rotation washer, and two nuts, both tightened quite snugly.
