He wants 48 spoke hubs on 36 hole rims. That would actually require drilling holes in the rim and would probably cause difficulty keeping the rim trued.Tater said:Sure you can if you don't mind grouping the spokes on the hub in clusters of three with an open hole between the clusters. It will involve two lengths of spokes as well. You are on your own as to calculating the required lengths.
ozzmonaut said:He wants 48 spoke hubs on 36 hole rims. That would actually require drilling holes in the rim and would probably cause difficulty keeping the rim trued.Tater said:Sure you can if you don't mind grouping the spokes on the hub in clusters of three with an open hole between the clusters. It will involve two lengths of spokes as well. You are on your own as to calculating the required lengths.
