69' Raleigh S.A. 5 speed
Sep 19, 2007
1,675
29
EASTERN CT
Found this at the dump today. 69' Raleigh Sprite with5 speed Sturmey internal gear hub. Needs some parts but the frame is nice and the rear wheel spins clickety-click.
Just going to start working on mine! It has everything but the headlight. I've got some all white tires for it.
This is my new favorite bike! :D I'm gonna' fix her up for myself. I've been saying that alot lately but I've been finding English bikes lately with my size frame. I have a woman's Raleigh in my shed that is the same color with nice fenders, a brooks saddle and shiny chrome. That bike is nice Kota. Please post some pics of the shifter and bell arm.... or just sell me those parts! :mrgreen:
Maybe I'll throw it in my truck, for Monson (not to sell).
Sorry it took so long. If you need more, let me know.
http://i239.photobucket.com/albums/ff182/KOTA777/006-4.jpg[/
[img]http://i239.photobucket.com/albums/ff182/KOTA777/007-5.jpg[/
[img]http://i239.photobucket.com/albums/ff182/KOTA777/005-6.jpg[/
Thanks for the pics Kota. I scored a new bell crank from Harris Cyclery up in MA. They have alot of Sturmey stuff stashed away plus new stuff. Very helpful, Sheldon Brown's old hangout. He has a lot of info on S.A. 5 speeds also on his site including the shift pattern TNT. Tony Hadlands site is a great reference source too. This hub is off the wheel now. Check out Hercu-stein to see what's in store for it. I've made a change in plans. 8) :lol: (sinister laugh)
Here's how they work. From Sheldon Brown's site:
The S5s are basically a 3-speed hub with two ranges.
The right lever or trigger selects underdrive, direct drive or overdrive, just as with the AW and other 3-speed models.
The left lever selects between narrow range 3-speed and wide range 3-speed. When the cable is loose, it's narrow range; when the left cable is tight, it's wide range.
Here's the shifting sequence:
Left: Tight; Right: Tight (1). This is the lowest gear, underdrive on the wide range setting.
Left: Loose; Right: Tight (1). This is the second lowest gear, underdrive on the narrow range setting.
Left: doesn't matter; Right: middle position (2). This is direct drive, so it doesn't matter whether wide or narrow range is selected with the left lever.
Left: Loose; Right: Loose (3). This is the second highest gear, overdrive on the narrow range setting.
Left: Tight; Right: Loose (3). This is the highest gear, overdrive on the wide range setting.
Shifting the right lever/trigger is the same as a 3-speed, can be done while pedaling, coasting or even pedaling backward.
Shifting the left lever works most smoothly if you keep pedalaing forward (gently) while shifting.
Simple enough huh? :wink: I'm gonna' have to mount an abacus to the bars to calculate what gear I'm in! :lol:
