Hi all. I just built a single speed Klunker and now I want to build a 7 speed. Is it possible and what advice can you give? I have a 1958 Schwinn American frame, forks and cranks. Thank you
That is something to think about. I have also considered making it a ten speed and using a different crankset. Will my frame accommodate that set up?It's certainly possible...but perhaps not so simple. Using a wheel with an internal gear hub (like a Sturmey-Archer or Nexus 7) is probably the simplest route. Adding a clamp-on style derailleur is anther alternative that comes with its own set of challenges. (For one thing, the original Schwinn chainring uses 1/8" single speed chain.)
Another obstacle that many planners overlook is the need for brakes. Your vintage frame almost certainly came equipped with a coaster...and coasters don't work with derailleurs. Not insurmountable, but more problems to solve. A multi-speed IGH w/ coaster makes for a nice clean installation.
I was thinking a traditional 5 x 2 setup. But either will do if it achieves the affect I’m looking for. Not sure if both are possible and if one is more desirable than the other. I am considering commuting to work by bike and my single speed Klunker would make it hard on the stretches where it is hilly.It could... There are certainly bikes that might work as a reasonable donor for a one-piece crank. In fact, a Schwinn Varsity from the '70s is common, cheap, and can supply a lot of parts for a potential build. Of course, such a build adds even more complexity with its front derailleur.
Oh wait...are you suggesting a modern 10-speed cassette or a traditional 5x2 setup? If it's the former, then yes there are adapter kits sold that convert the Schwinn's bottom bracket to accept a square-taper cartridge. Just about anything is possible, if you throw enough money at it.
