Would this work, it has a 131mm lock to lock, with a 2 1/4" distance between the flanges (36H)? Can it be re-spaced on each side by changing out the spacers behind the lock nuts?
ooo, I like that. what if you rotated the clamp 90 degrees so that both nuts were pointing toward you? Then maybe you could either just use the remaining exposed thread as the shaft for the cantis to pivot on...dracothered said:How about doing something like this, do you think it will work?
Dr. Tankenstein said:I just tried the OCC rear wheel on the front of the Beast.
The hub is too wide to fit the forks, so forget my band brake idea. Unless you make a set of triple tree forks using the trees from a motorcycle.....hahahahaha!
That would be light, not!
But man, it would make for big ol' chopper or boardtracker wouldn't it?
Cheers,
Dr.T
dracothered said:Would this work, it has a 131mm lock to lock, with a 2 1/4" distance between the flanges (36H)? Can it be re-spaced on each side by changing out the spacers behind the lock nuts?
Using a derailer as the starting point is an interesting idea, I will have to look at one when I get back from the men`s retreat I am on.kingfish254 said:I wonder if a regular front derailleur hanger could be modified to brake bosses???
The one I have looks as if it might be able to fit the fork tube, but I'm not sure if it has enough metal in the tab area that is where it hinges. The metal is about an 1/8" thick that clamps around the seat tube. Would it be strong enough to withstand the braking action though?dracothered said:Using a derailer as the starting point is an interesting idea, I will have to look at one when I get back from the men`s retreat I am on.kingfish254 said:I wonder if a regular front derailleur hanger could be modified to brake bosses???
