I have an idea for part of an upcoming build project that involves two headlights, and possibly a tail light. Ideally, I'd like to run them from a hub generator. However, it seems that any that I've seen provide enough current to light one 2.4W incandecent headlight bulb, and possibly a lower-wattage tail light. I have a couple issues with this. One, it isn't enough for my second lamp. Two, I don't want a dim tail light.
So, it seems like there are a couple options. I could run all the lights on batteries, but that defeats using a generator (and being battery-free). I run all the lights from a 6V flashlight battery or a multicell pack like RC cars use, but I think I'd only want that if the generator would be effective at recharging it, which I don't know about. Or, I could use LEDs to significantly reduce the amp draw, but I seem to be having difficulty finding 6V LEDs flashlight bulbs, or at least ones that have a wide enough light beam to actually make proper use of the headlight's reflector. Not much point in having a very narrow, undispersed beam. Either that or I find a suitable headlight that uses LEDs that are designed to run off of a generator.
What are other people doing about this? Can a generator that puts out 1/2 an amp at 6V keep a NiCAD or Li-Ion battery charged? Any thoughts on this would be appreciated.
