Spacer washers on both sides of the rear hub should fix the rear clearance issue, you may have to bend slightly more to give them clearance though. I seem to remember someone on here adding a spacer washer between the chainring and the lockring/inner bearing race to space the entire cranks sideways, not sure if you would gain enough room on this bike, but that would be the easiest way, the next way I can think of would be switching to a spider/bolt on chainring center and spacing that out to fit... The last way I can think of is the most drastic, but is the way I would do it, cut/move/weld...
This is a three piece one I did to space further in, no reason it could not go the other way...
Multi-speed set ups quite often have a fair amount of offset between the front and rear, you may find it is a non issue once the rear is fixed... :wink:
