cman said:Make sure that you order the correct axle length.
http://www.niagaracycle.com/categories/ ... red&page=3
He can't as he has an Italian BB.Sinner4 said:Yes, get this. Mine was $25 from my closest LBS. Takes 15 seconds to install.cman said:Make sure that you order the correct axle length.
cman said:
Chips_Mahoy said:My axle length is like 146mm but it doesn't have the "bolt on" crank arms. They slide on and then a wedge like pin goes in to hold it. I don't mind changing those. If the ones from Niagara Cycle that Sinner4 posted will work with this particular bike and small BB, I'll probably order one.
cman said:Replace the BB shell and use the BB cartridge that came with it.
Bicycle808 said:so.... what happened?
Chips_Mahoy said:Bicycle808 said:so.... what happened?
I'm about to leave to go to the bike shop right now. I found the missing bearing cup so all I have to do is find the right bearings and I'm good!! Stand by for an update later today....
So the threads ain't damaged?
