What are those little posts called that are welded on to the seat stays and fork that you attach brake arms to?
And... do you know if there are any made that can be clamped on, or screwed or bolted through the seat stay?
I've run into a major snag with my son's upgrade. I finally got it spread, and I've fit the wheel in with the derailleur mounted. I mocked up the caliper brake, and it rubs the stays. So... I'm thinking maybe I can put posts on there, and go with a linear pull brake.
Any help is greatly appreciated!
