I have a 50s Goodyear that I'm building.. I most definitely want to use the headbadge but I want to take it off for paint stripping and painting.. The rivets or studs that are holding it in are seriously tough steel.. They are more of a pin than a rivet because nothing protrudes into the headtube.. I can see where they are but they are flush inside.. I do not want to damage the badge at all. Drilling is not an option because they are rounded, I cannot pound them out from the inside out because the lack of space inside the headtube.. I was thinking a dremel with a small grinding stone?? Any advice would be great. Also for re installing it.. Any advice there would help.. Would you tap the hole? Re-rivet it? It's the only thing holding the paint process up and I really don't want to paint it with the badge on but if I have to I will I guess.
Thanks, zach
Thanks, zach
