Cable barrel adjuster stuck.....
May 19, 2013
222
181
Chain is broke on gear adjuster...barrel will not screw off to replace. When I turn barrel the whole cable turns with it.
Trying not to break as I don't want to replace cable.......Don't know if I should try and hold cable and force it......
It is an old 3 speed twist grip...looks like it would not be fun to replace. '66 Hi Way Patrol by Columbia.
    66.1 KB
    32.9 KB
Hit it with some PB Blaster and try again in 24 hours. I’ve been using the same can of PB Blaster for 20 years. Amazing stuff and a little goes a long way.
Give lube a go. If that doesn't work, you're replacing the chain and rod anyway, so I'd cut the chain to detach it from the cable. Then, you can work on each half as a separate problem--i.e. grasp the barrel and twist the partial chain out.
