Chain wheel making noise.
Jan 25, 2011
43
York, Pennsylvania
OK so whenever I pedal the area around my chain wheel makes a clanging noise. It sound like the chain and chain wheel are grinding together. Also on a side note can you use wd40 to oil the chain :?:
Does it make the sound once per revolution? If so, the crank is hitting the chain guard or the kickstand on the other side.
If it's making a constant clanging, check the clearance of your chain guard to the chain and the sprocket.
see if the chain is rubbing the other front sprocket...
edit: is yours a 10 speed like the pic? With two front sprockets?
different from all the other links :mrgreen: :mrgreen: :mrgreen:
..............should have an oval plate on one side...
check the front derailer (chain mover :mrgreen: ) to see that the chain is aligned right and not too far off to one side...
Ok I found the problem :mrgreen: . I took the chainwheel and all that apart only to find my bearings are shot :? . Also my right pedal will not come off :x
up date it came off
Pics of the bearings
