StellaMae said:
I just learned that the hard way.
After we installed the internal hub, I still needed to bring the gear ratio down a bit. We went to 20 T on the front and I can't get any purchase pedaling at all, even in 3rd, on a descent. I'll be notching back up to 36 T very soon.
Wait, I'm sorry, I wrote that wrong. I went to a 28T on the front. This may not apply in your situation, but someone else might find the math useful:
xxT is the number of teeth on the gear: higher = harder to go up hills. I started with a 1-piece, 46T chainring. Totally standard and common. I also have a Shimano Nexus 3-speed internal gear hub on the rear. That changes things just a little.
I could switch out my 46T for a:
36T (36/46 = 22% easier): Probably a good choice for most riders
28T (28/46 = 39% easier): Probably entirely too big of a jump, resulting in pedals that feel loosey-goosey, increasing the likelihood of your foot slipping off a pedal and hitting the asphalt (ask me how I know) and generally making you look silly as you pedal really fast. Guess which option I picked-- yep. I'm moving back up to a 36T.
And, since you only get partial credit if you don't show your work, here's the math:
Front chainring: 46T
Rear sprocket: 19T
Baseline Gear Ratio = 46 / 19 = 2.42
HOWEVER: having an internal hub modifies difficulty by +/- 36%, so:
With a 46T, you're at 1.55 | 2.42 | 3.29
With a 36T, you'd be at: 1.21 | 1.89 | 2.56
With a 28T, you'd be at: .94 | 1.15 | 2.01
By comparison,my boyfriend's front gears are 28T / 36T / 44T and the middle gear on the back is 19T, giving his bike a gear ratio of 1.47 | 1.89 | 2.31.
Perhaps more info than ANYONE needed to know, but I'm kind of proud of myself for figuring it out.
