The Renaissance Man
__CERTIFIED DIVER__ (Open Water & Open Dumpster)
Staff member
Moderator
Pro Member
There is one thing that has been bugging me Mike that you have the ability to correct and the time is soon before you get to the paint stage. The dual brake alignment problem can be corrected by creating a new mount instead of trying to piggy back off of the existing fender mount.
The problem is that the current mount is not in line with the axis of the wheel. My suggestion would be to make a new mount that will locate the two calipers in line with the axel. It's hard to say if you would ditch the existing fender mount all together or leave it and add a second bracket dedicated to only the brakes. You would be able to tell more about it after playing with the set-up.
Here's the idea:
Here's how it is now:
Here's the idea:
