First off please wait for other replies before doing this.
From the looks the original knob it is pressed or glued on. If you want to save it, might look for some wiser advice, otherwise pull really hard or cut it off(the plastic not the metal).
As far as getting the other one on, cutting the hole, if you do not know anyone with a mill, take a drill bit that is one size smaller than the width of the shifter bar. Then drill several holes in a row the length of the bar on the bottom of the 8 ball, and tap it on, if it is still to tight clean up with a file, if it is loose then use some tin foil and epoxy or lock tight to hold it on.
Now this is the redneck way of doing things, there is probably a better way, but if not give it a try.
