I picked up a new Felt 1909 a couple weeks back and decided to upgrade to a 3 piece crank with sealed bottom bracket. After driving in the bearing cups with a dead blow hammer the axle was very difficult to install. I had to use the dead blow, and whack the axle quite a bit. After installing the cranks I noticed they didn't spin very well. In fact, they were terrible. So I took everything apart and realized the right side of the bottom bracket on the frame is not totally round. I'm not sure of I should try something to fix the bottom brakcet on the frame, or grind off a bit from the bearing cups so it doesn't collapse as I drive it in. Any thoughts on the best way to deal with this?
Is it normal for the axle to slide right in with the bearings in hand, but be tight and require pounding once installed in the frame? I'm wondering if I shoudl use a cylinder hone to open up the bottom bracket a bit, but I would hate to ruin the frame.
