I recently received a nice, what appears to be Murray-built, Hiawatha from a forum member. Unfortunately, FedEx's kind and loving hands caused the threads on one side of the axle to get kludged up. The hex nut moves but it takes alot of effort. I tried to back the nut off the axle to try to adjust the bolt threads. It may have helped a little but I think the nut threads have also gotten a bit messed up. Because of this situation, I'm having difficulty adjusting the hub cones properly and keeping the wheel secured to the forks at the same time.
So first option is to buy a few nuts to sacrifice (anyone know the TPI on a 5/16" axle???) and try to use them to beat the threads back to where they belong. Is this a good idea or stupid?
Second is to get a die to realign the threads - don't know if this is an option and again, need to know TPI.
Third is I see that Wald sells an axle rebuild set, but the problem is they don't include the lock nuts that go on either side of the hub.
Any help would be greatly appreciated.
