Just got this schwinn super seven off a local market listing.
Thinking was too clean it up make adjustments and use it as my daily and weekend bike and just use the cruiser four for those nice flat trails on occasion.
Once seeing it in person things change. Rides ok but pulls to the left real bad. Great tires and from rim.
Further inspection and the forks are both bent to the right about 1/2-1 inch, also looks like the frame is tweaked up towards the headset, might be an optical illusion due to the bent forks?
The nexus 7 speed shifts great and seems to work just fine. However the rim is bent and has an area three spokes wide that is flat. I know I can true it but the flat spot, I don't know?
So now thinking on using the nexus hub and upgrade my cruiser four with this 7 speed.
So wondering if I can relace the front rim to the nexus hub? Rims are same make and spoke count? Not certain if it is doable that I can actually tackle it??
