In the case of putting two frames together, good ol' cutting and hacking, I just align it by sight. Your eyes don't lie, and will see that something is off with even a tiny misalignment.
Boy this forum has got me thinking and wishing. I have a bunch of old frames, perhaps I could come up with a Yooper frame build? I could cobble them together with wire and sheet metal screws. I wonder? Sounds like a project for a build off. The rules state the bike has to be ridable. I could ride a bike like this a few feet before it disintegrated at a sub atomic level. Nothing is permanent, not even magnets.
I have a small propane type MAAP torch. I can't get anything hot enough to braze with it. I have an old Miller 220 volt AC welder but I am no good with it. I can do simple stuff like ugly tack a broken strap from my hand cart, but that has come off after a few years of abuse. I been using it with only one band, too lazy to fix it again.Ever consider using the metal screws to get it in one piece, buy a cheap MAAP torch and bronze or brass rod (I can afford one and I am pretty much US Poverty level), brazing the seams, then brazing around the screws for a permanent fix and grinding the heads down before painting the finished product? Those screws make a great 'tack weld' of sorts while you braze...
I want a welder Sooo bad-but MAAP torch and bronze rod will get a lot done. Not that my first experiments aren't hideous due to my lack of skill so far, but I Will get better...
This sounds like exactly like what I did for HeadBanger. Front frame was from a MTB that I mated to an OCC rear clip. Simple jig was made from unistrut, dropouts had threaded rod through them, and it allowed me to move it back and forth for the fitment of the suspension bracketry and where I wanted to weld in the pivot.Adding a bar here or there would not be a major problem for me. But I have never cut a frame in half and put it back together aligned properly. Lets say I take two frames and make one long one out of the two. Does anyone have a simple alignment process to get the two wheels in the same track and not twisted to the left or the right?
Any pictures of the alignment process just before welding?
Thanks
Looks good in the photo! You are well on your way, hope you keep at it!
I am looking into wading into the water of frame building
Will we be seeing some more scratch built frames for RRB-BO#10 come May 1st?Totally not experienced here, but I'm thinking of doing the same thing, Renaissance Man.
Not me, I'll be on the sideline watching.Will we be seeing some more scratch built frames for RRB-BO#10 come May 1st?
Nooooooooooooooooo!Not me, I'll be on the sideline watching.
I was amazed, the welding is the easy part. Its fitting and bending and getting things straight. I need to take more time. This first effort happened without planning. I had the parts and the welder was there, it was too good and opportunity to let it pass by. I am really happy I did it but at the same time disappointed it didn't work out. I really think frame building is in the scope of all our members if they had the welder I used, it was easy. I am thinking about a cheap flux core welder but that probably would frustrate me after using the $2000.00 Miller.Looks good in the photo! You are well on your way, hope you keep at it!
Wait, May 1st? RRB-BO #10?Will we be seeing some more scratch built frames for RRB-BO#10 come May 1st?
