I originally was going to enter a trike, but saw the risk of crashing and ER visits and scrapped the idea. But now I think I have solved those problems and will now make a front wheel drive fat tire trike. There will be enough weight in the rear to thwart any end over enders and should be wide enough to be stable even with the seat 36 inches high or more.
With the drivetrain up front, the two wheels in the rear just roll (and brake on this trike), like a classic child's tricycle.
I definitely will have a big seat and tall apes. There should be enough room for two people to stand and hitch a ride on the back platform.
I need a crankset up front as direct drive is slow on a 30" tire and needs a unicycle hub. I will use the wheels and gears, along with the disc brakes, from the Orange Crusher. Probably the crankset too. It may supply most of this build.
The springer fork is heavy and will provide a good solid base for the front bottom bracket.
I'll have to make up another wheel for the rear and figure how to make the frame.
I'll try to draw a plan up and post it.
![0ca130e6e130b03bed0f56681f73f29b.jpg 0ca130e6e130b03bed0f56681f73f29b.jpg](https://cdn.imagearchive.com/ratrodbikes/data/attach/265/265361-0ca130e6e130b03bed0f56681f73f29b.jpg)
![12 May 2024.jpg 12 May 2024.jpg](https://cdn.imagearchive.com/ratrodbikes/data/attach/265/265362-12-May-2024.jpg)
![12 May fork.jpg 12 May fork.jpg](https://cdn.imagearchive.com/ratrodbikes/data/attach/265/265363-12-May-fork.jpg)
